Vac jumping out of gear
Raymond
12-21-2002 12:22:58
I have a 1949 VAC that will pop out of gear under a heavy load(such as tractor pulling). Is there a chance that there an easy fix or are the gears probably just worn out. I'm not familiar with working on transmissions or rearends so I'm kinda scared to just start ripping into it just to hope something jumps out at me. I have a completey rebuit engine, new clutch, pressure plate and throwout bearing. One other thing, I noticed that when I took the brake discs off, the inner metal surface on the chasis of the tractor that the discs press up against are actually cracked all the way down through. How bad is that?
mj
12-24-2002 21:33:31
 Re: Vac jumping out of gear in reply to Raymond, 12-21-2002 12:22:58
The manual lists 4 possibilties for "Transmission slips out of gear"
1-Weak or broken mesh lock spring (under shift rod cover, one for each of 3 shift rods, i.e. 1st & 3rd, 2nd & 4th and reverse).
2-Mesh ball lost (under mesh lock spring).
3-Gears worn, walking on shaft.
4-Shifting fork bent, partial engagement of gears.
NOTE- To remedy any of above the manual says to replace offending part. In the event of a bent shift fork you might be able to straighten it.
Jeb Mccranie
12-21-2002 15:28:52
I have an International grain truck that did the same thing. It turned out to be the synchronizer in the transmission. Not to familiar with any of the letter series cases but check your shifter.
Dan Kelley - Mr. VAIW-3
12-24-2002 08:27:44
 Re: Re: Vac jumping out of gear in reply to Jeb Mccranie, 12-21-2002 15:28:52
Synchronizers? I could be wrong, but I don't think there were such things on tractors in 1949. My 1945 VAIW-3 has straight-cut gears, and definitely does not have synchro-mesh.
Your plight scares me for you. Sorry I can't be more help. I was lucky. When I looked at my gearbox a few years ago, it was beautiful inside.
