VAC main bearing thrust washers
Captain.n/e,Mo.
12-20-2002 15:14:28
Can you buy just the thrust washers. I just tore apart an engine someone screwed up the washers in . The bearings are all new. What happened is they put both washers in the front and nothing in the back side and it broke one washer. If I can't find just the washers I plan to try to braze the bad one back to where it is useable and put it in the front . everything has almost no time on it since it had a rattle when they started it.
CASEPOWER
12-20-2002 15:53:56
 Re: VAC main bearing thrust washers in reply to Captain.n/e,Mo., 12-20-2002 15:14:28
I have used ones $5 each
thanks
12-21-2002 07:50:18
 Re: Re: VAC main bearing thrust washers in reply to CASEPOWER, 12-20-2002 15:53:56
someone already emailed me direct with $8 new ones and shipped them today. thanks
