Case VAI
Michael Goulart
12-19-2002 16:46:09
I would like to thank everyone who helped me out with all the questions I had. I now have my little VAI up and running. They were not kidding when they said the Industrial tractors were hi geared! This thing will get up and go. The little engine has lots of power and great compression. The man I got it from said it had a new engine, and I really don't think they ever had it running or running right since the rebuild. I think I come out ahead on a trade finally. I traded this VAI for an old Farmall B with a very stuck engine. I mean this engine was locked down good and two cylinders were junk. Besides, I love the little wide front. Now to get a three point on it. Which shouldn't be hard, I may build one since it has auxilary hyds. Thanks again guys. I'll try to post a pic of it in the gallery, so go check it out. It's not pretty, but it's paid for and it runs excellent.
Mike Schotte
12-20-2002 04:05:57
 Re: Case VAI in reply to Michael Goulart, 12-19-2002 16:46:09
Sounds like a neat project- good luck.
Here's the pic of Michael's VAI:
">Link
-Schotte
Clint
12-19-2002 20:47:06
Michael give me a call I have a Case 3 point that with a little help will fit on your VAI. It came off of a VAC.
Raymond
12-21-2002 12:09:36
 Re: Re: Case VAI in reply to Clint, 12-19-2002 20:47:06
Clint, do you have the retrofit stockman three point hitch designed for the old VACs or a three point off a newer VAC? The newer hitches won't bolt onto the old ones because the housing is totally different. If you have the stockman hitch and it doesn't work out with Michael, I'd be interrested. I'm in Ohio.
Michael
12-20-2002 07:37:23
Clint, can you email me some info on the lift, such as price, condition, and location? Thanks.
