I am afraid I am not as sharp as Mike billed me. There are BASICALLY three compression ratios that I am aware of. The original dual fuel setup that came with the L and dual fuel LAs used the standard head (I don't have my parts book here for a number) with a low compression piston that made TDC about 1/4" below deck height. This was about 4.2 : 1 compression. The standard gas setup used the same head with a piston that made TDC even with the deck. This is about 4.8 : 1 compression. The basic propane setup used this piston with a higher compression head for about 7.5 : 1 compression. There were apparently two different propane heads - one that came with the factory propane tractors that came out around 1951 or 1952, and a factory propane retro kit for the older tractors to convert them from gas to propane. Mixed in all this there were some pistons and heads that were referred to as "high altitude option". Some of these are the same as the propane parts. Needless to add, it gets a little confusing. The best way to sort it out is to get a parts book (make sure it is a late parts book that will cover all versions of the LA, not an early original that does not have propane in it) and work all the numbers out. To make it even worse, M&W and others sold high compression pistons and overbore kits with larger pistons and sleeves, so any one tractor can wind up with any number of compression ratios. I have heard of some people having pinging problems with the higher compression ratios, so tuning may become an issue - ignition timing, fuel octane, etc. I would think that if you go too high compression with the stock cam, you could generate some pressures that the composition head gasket and original head bolt arrangement would not tolerate well. Aftermarket cams with longer duration actually lower compression pressure, especially at low rpm. If you have ever listened to a small block Chevrolet with the old 375 FI cam, that is a good example. That lopey, uneven idle and poor low end torque are due to poor combustion. I believe the factory version of that engine was 11 or 12 : 1 compression ratio. I have not run one of these high compression tractors yet, I have one that is waiting for me to come its way with wrenches, another that seems to be lightly stuck and is soaking. You might try posting on the pulling board for some better info
