Why did Case discontinue chain drive?
Rick
12-17-2002 06:17:05
I have herd many good things about these older case transmissions, so why did they discontinue making them in the latter tractors?
RobertTX
12-17-2002 08:45:50
 Re: Why did Case discontinue chain drive? in reply to Rick, 12-17-2002 06:17:05
On the larger tractors, the original design that was introduced on the L in 1929 was used until the 60's on the 930. I think the newer tractors just had too much power (the 930 is nearly double the L) for the old design. Another factor may be the higher speeds of the newer tractors also. As the speed of a big heavy chain increases, the loading on it increases.
Bob
12-17-2002 18:36:29
 Re: Re: Why did Case discontinue chain drive? in reply to RobertTX, 12-17-2002 08:45:50
It is something I have always wondered about as well and would like an engineering explanation of advantages and disadvantages of chain drive as I am not sure about power or speed limitations on chains. (speed example, motor cycle chains)
I would also like to know about the relative cost of chain drive (with big reduction from diff to axle) verses plannetary reduction, as I have heard cost as an explanation for discontinuing the chain drive.
The chain drive in old Cases was both durable and easy to maintain.
Bob
cb (hint follow the money)
12-18-2002 11:44:08
 Re: Re: Re: Why did Case discontinue chain drive? in reply to Bob, 12-17-2002 18:36:29
I think it was done from a marketing standpoint.
Most folks in the 50's wanted more gears. If the tractor could not pull the disk up the hill in 5th gear they wanted to have a 4th gear to slip into.
The old LA had too few gears.
You have to sell something to stay in business. A great design and something that is easy to work on and lasts forever is one of the reasons The JI CASE Co. is GONE.....
more
12-17-2002 20:25:59
I think the power, speed situation is the answer. As speed is increase too much a chain want to go to the shape of a circle and ride away from the sprockets. There are too many moving parts in the chain while gears have only two. The gears are more efficient. Deere had already gotten away from the chain: the D had it, the R didn't. Much like two cylinders the chain was a thing of the past.
Jim P
12-18-2002 22:22:45
 Re: Re: Re: Re: Why did Case discontinue chain drive? in reply to more, 12-17-2002 20:25:59
They quit the oil bath clutch at the same time, but they went back to it in the form of a power valve on the 70 series. John Deere went to a oil clutch also some years later. The difference was it was oiled from the tran. instead of the engine. Oh yes a chain could break and roll under the sprocket and bust the bottom out of the Trans.-final drive housing..
