Cold Weather Start
Illini Case
12-16-2002 19:02:59
Is it possible for a diesel to start without ether in cold weather if it has low compression/bad rings?
Eddie in KY
12-18-2002 19:40:03
 Re: Cold Weather Start in reply to Illini Case, 12-16-2002 19:02:59
I have a water heater in mine, in the lower radiator hose. I have a DB 885 that is ether addicted, not because of me. Dont know how well it works, I havent gotten the chance to try it in real cold weather yet. If this doesnt help I'll try a dipstick style heater too.
Goof Off
12-17-2002 12:41:21
Yes it is possible to start a low compression worn out deisels in cold weather in one of the following ways. 1 Put the tractor in a heated building when not in use. 2 Put a big block heater on the tractor and keep plugged in when not in use. 3 Start tractor every 30 minutes and let run for 10 minutes. Other wise it is hard to start them old deisels when they are tired and worn out. If not too cold make sure your batterys are in good condition and they turn the motor fast, then you can use starting fluid carefully. Make sure you spray it in as the motor is spinning over.
