Stubborn steering
Jeb Mccranie
12-15-2002 14:36:20
When I drove my 1290 this morning,I was suprised to find that when I turned the wheel nothing happened.Almost ran through a gate. Let it run for 10 minutes and it worked fine.Except when I idled it down, it became very hard to steer. Never done this before,and it was only 40 degreeswhen I started it up.Also, does the power steering pump use its own fluiand if so where do I check/add some?
david
12-15-2002 15:41:38
 Re: stubborn steering in reply to Jeb Mccranie, 12-15-2002 14:36:20
Yes, it has self contained power steering. Sounds like low fluid, prob. some air. Power steering resorvoir is on the right side between the fuel transfer pump and timing gear cover. Has an (I think) 1-1/8" fill plug at about a 20 degree angle. Fill full.
