Photo Test- burning a stuck engine
Mike Schotte
12-14-2002 15:34:54
Hi All,
I signed up for one of those free photo hosting things today- so I made a quick photo album to test out linking the images. I hope this works:
This is the 1945 dual fuel SC project tractor that I got at auction in November. The head had been removed before I got it, but was left sitting on the tractor. I blew out the leaves and dirt that had gotten into the cylinders with an air hose, and have been soaking the pistons with Marvel Mystery Oil for a couple of weeks.
You can see the tops of the pistons here- it appears that they are aftermarket button top aluminum pistons:
third party image
Since I don't have much to lose- I thought that I would try a trick that I read about over on the JD board in order to break the bond between the pistons and sleeves.
I lit the MMO in the cylinders with a torch and let it burn down. While the sleeves and cylinders were still warm- I added more Marvel for this week's soak. Next time I'm going to use the recommended diesel fuel or brake fluid- as I don't think that Marvey Mystery Oil burned very hot. The sleeves were only warm to the touch when everything had cooked out of the cylinders.
third party image
Hopefully the burn will break the rust bond at the edge of the pistons and allow the oil to penetrate further for the next soaking. I've read that with 4 or 5 burns you can get the engine to unstick. We will see! Thanks to Clooney on the JD board for the tip.
It will be a few weeks before I know if this trick will work, but I will keep everyone posted on my progress.
-Schotte
ff316
12-15-2002 09:42:45
 Re: Photo Test- burning a stuck engine in reply to Mike Schotte, 12-14-2002 15:34:54
Good "Schotte" there Mike ! ;) Nice pictures on your page, love to see them in their "natural habitat".
A friend of mine once unstuck a hit-n-miss engine by burning coal in the cylinder. He had it running a few days later.
Have a good one, Fireman
duane
12-15-2002 08:37:20
Howdy Mike,
Where was the auction at in TX. and how often are they???
I live in the Houston area and am always looking for a good auction with lots of restoration projects.
Mike D.
12-15-2002 06:29:51
Nice photo collection. Thanks for putting them out for us to see. I hope you will take shots of the work as it progresses. I will be interested in reading about what has worked, and what hasn't worked out. Good luck to you. Mike D.
Les
12-14-2002 18:39:30
Interesting, Mike. The ad at the top of the page was for "Basket Nation". Are you sure that isn't a "Basket Case"? ";^)
James
12-14-2002 18:10:47
If I may, how much do you pay for an SC in that condition? What part of the country are you in?
Mike Schotte
12-14-2002 21:03:18
 Re: Re: Photo Test- burning a stuck engine in reply to James, 12-14-2002 18:10:47
Hi James,
I'm located in Central Texas. For years I thought I was the only guy in the state who owned an SC- but they are around... just not as plentiful as in other parts of the country.
That's why I was excited to find these two at the salvage auction. The '45 is in the roughest shape- but the '49 I may be able to get running soon. After that, maybe I can figure out what caused it to be parked in the first place.
To answer your question- I got both tractors (they were grouped in one lot) for $150.00. I only had to wait out in the rain for 12 hours of auction to get them that cheap, though!
I knew that there was more than $75 worth of parts on each one, so I figured I couldn't lose. Since the wheels were adjusted all the way out, I had to hire a rollback wrecker to move them... so there went another $120.00.
As Les noted, they are probably "basket" CASES- but I've got to at least try to see if there's any life left in the old girls...
-Schotte
Ralph
12-14-2002 17:58:10
Nice pictures, Mike. That's a new one on me but at least you have the advantage of having the head already off. Good luck with it. I got my Minnesota LA unstuck with PB Blaster, Marvel oil and patience patience patience. Let that baby soak as long as it takes.
Jim Y
12-14-2002 19:22:16
 Re: Re: Photo Test- burning a stuck engine in reply to Ralph, 12-14-2002 17:58:10
Mike good luck in trying to unstick your sc. I just wanted to tell you about a recently freed up engine that we did . The head was off too. It was a newer model vac g148 head. Know this is a little different than most of the posts you read, but I had heard from a older man with a white beard down to his chest. He always unstuck his engines by soaking them with coca cola the real stuff. It has muratic acid in it. Poured it in and after all the fizzy was gone I started noticing little chunks of rust were floating to the top. So we soaked it for couple of days with coke. It works on car batteries why not on this? Then we soaked with transmission fliud for another day. Then we did what you did by burning the transmission fluid out of the sleeves. Didn't what to put pressure on the hand crank and twisting into a snake. Then after that we put a 15" adjustable jaw wrench on the crankshaft pulley nut and a motor crane and placed a bolt through the back of the wrench so the hook wouldn't slide off. Started jacking the wrench up and letting the weight of the tractor and gravity do all of the work. Started tractor lifting the tractor and took a 1/2" disk the size of the piston and took a three pound hammer and hit each piston 5 or 6 times. After doing that we noticed that front tires were no longer an inch in the air. So I started lifting the wrench again and noticed that the pistons were starting to move slowly but were moving so I re-adjusted the lift and wrench about three times and had just about gone full circle with the pistons. Thought since it worked for us it might work for someone else . Good luck JimY
INCase
12-16-2002 05:53:55
 Re: Re: Re: Photo Test- burning a stuck engine in reply to Jim Y, 12-14-2002 19:22:16
what did you do after it was unstuck? Did you hone the cyld. and put in new rings or did more need to be done??
Exceed the daily limit in FOUR HOURS!
12-14-2002 21:06:28
I posted this message at 6:00 p.m., and at 10:30 p.m. I'd already exceeded my 5 megabyte a day limit on the "free" photo posting.
Sorry about that. The photos will be back again tomorrow until another 44 people look at them.
The link at the bottom of the first post was to an album that had pics of the whole tractor, too.
Good Night, -Schotte
