Impossable SC parts
James
12-14-2002 04:00:27
Im looking for a set of used pistons and sleeves for a late foot clutch SC. I cant aford new ones or find them. They dont have to be great just usable only going to be a parade tractor. Thanks
Duner Wi
12-15-2002 15:46:32
 Re: Impossable SC parts in reply to James, 12-14-2002 04:00:27
This might work, no guarantees, SCs had several different piston sizes over the years. 3 1/2" thru 3 11/16. Depending on your piston size say 3 11/16 and you could find a set of 3 1/2 inch sleeves you probably could bore them to fit your pistons. Don't bore them to size but just to fit your pistons. Now get a set of rings for your pistons and file the end gap till correct in your slightly undersize sleves. Check your ring grooves and if in excess they can be machined and a spacer put in. Only other thing I can thing of is to bore you sleeves and put a sleeve with in a sleeve. This might work only on the 3 1/2 inch pistons. Sealed power makes 1/16 wall sleeves with a lip on the top. Not sure if any of this will work but can't see why it would not. Good Luck.
Jerry
12-14-2002 11:41:54
Send me your E-mail address Im might have what you needs. I would be interested in buying this rig if you are not too far away.
