David Brown remote hydraulic swap questions
Jeff
12-13-2002 15:25:46
I have a Case 380 and a Case 1410 for parts , both are David Brown tractors. 1410 has remotes 380 doesn`t can I take the remote stuff off of the 1410 and put on the 380? It looks like it should work but I thought I would ask thanks.
Elmer
12-13-2002 15:37:15
 Re: David Brown remote hydraulic swap questions in reply to Jeff, 12-13-2002 15:25:46
The base plate is different. You need a base plate from an 880, 885, 990, or 995. The 1200, 1210, 1410 have a front pump and an external line fed to the base plate.
Jeff
12-14-2002 13:20:06
 Re: Re: David Brown remote hydraulic swap questions in reply to Elmer, 12-13-2002 15:37:15
Would you know where I could get the plate i need? Thanks
/';lkj'l
Elmer
12-14-2002 16:33:56
 Re: Re: Re: David Brown remote hydraulic swap questions in reply to Jeff, 12-14-2002 13:20:06
I'll see what i can find up here.
