Case terratrac
Jeff
03-28-1999 02:45:22
Hello out there,
I have a case crawler/loader that needs i.d. There are no numbers in plain view. A local dealer told me it was a 356 terratrac. It has a winch on the back, a four cyl. gas motor made by continental, and is a little smaller than a 310. Can anyone shed some light on when they made this model? Any other info would help. Thanks, Jeff.
DAN
01-01-2002 15:44:34
 Re: case terratrac in reply to Jeff, 03-28-1999 02:45:22
JEFF, I DON'T KNOW IF YOU EVER FOUND THE SERIAL NUMBER TAG, BUT I DID OWN A 556 AND AT PRESENT STILL OWN A 310-C. THE NUMBERS WERE LOCATED ON THE LEFT HAND SIDE OF THE SEAT AS YOU ARE SITTING ON THE MACHINE. (ON THE OUTSIDE OF THE TOOLBOX/HYD.TANK WHICH EVER THE DESIGN OF THE MACHINE.) THE 356 WAS BUILT FOR 2 YEARS. THE SERIAL NUMBERS WERE, 1955-( 001 ), 1956-( 062 ). THE 556 AND 310-C WERE THE SAME BASIC TRACTOR, BUT THE 556 HAD THE CONT. FLATHEAD AND A TORQUE CON. WHILE THE 310 HAS A CASE ENGINE. GOOD LUCK.
Jerry Brown
03-28-1999 21:14:18
Jeff try:>Link
this>Link is the unofficial terratrac home page and he has more information than anyone else I have
seen on the internet when it comes to Terratracs.
Check out the article as well as the pics he has
available and the serial no. list. The sales brochure is helpful as it has pics of crawlers without blades or loaders and you can see sheet metal clearly. There is no 356 pic on the site but there is a 300 pic.
I have a sales brochure on Terratrac loaders from the mid-fifties and they only show 400 and 500 series with loader buckets on the brochure.
I am always looking for more Terratrac stuff myself as I have a G500 with an updated 6-way blade and ROPS.
If your engine is a flathead continental you can look on the cyl head and it should have a cast no.
that starts with an "F" such as F140, F162, FA162
etc. The engine size will be a small clue to the
dozer as the 400-600 series had F162 or FA162. Incidentally, the number is generally the cu. inch
displacement of the engine. There should also be
an engine identifying tag on the left side of the engine block (as you look from back to front of
dozer)that has more complete information.
jeff
04-02-1999 00:38:04
 Re: Re: case terratrac in reply to Jerry Brown, 03-28-1999 21:14:18
Thanks for the info Jerry!
