Clutch adjustment
Glenn
12-10-2002 11:28:28
Greetings all: How do you adjust the clutch on a Case model "D.O." We've looked and looked and so far been unable to find any kind of an adjustment bolt, nut, screw, lever, etc. Any help you could give would be great as clutch is slipping badly. Thanks - Glenn
robert
12-10-2002 17:25:18
 Re: Clutch adjustment in reply to Glenn, 12-10-2002 11:28:28
he is correct.It sounds hard but is a snap once you see it.The first time in may take awhile to see that little pin that you need to release so plate can rotate to adjust.slowly keep turning over by hand until you see it.be safe and remove plug wires.
Bob
12-10-2002 16:06:52
Clutch adjustment is the same on all C, D, L, LA etc Case tractors.
Remove the inspection plates on each side of the clutch. Have a look inside with a flashlight. You will see the whole clutch assembly.
The adjustment is by a yoke at the back of the assembly. There is a locking pin in it that has to be pulled back. Turn the transmission with the belt pully until you can get at the pin. There was a tool supplied with the tractor to pull the pin, but you can pull it by hand or with pliers etc.
Turn the yoke clockwise to tighten the clutch. It does not take much turning. Then make sure the locking pin re-engages in the next hole. There are 20 holes around the clutch for this adjustment.
It sounds complicated, but is very easy.
Bob
12-10-2002 16:04:17
