CASE SC
Cory Rusher
09-25-2006 11:52:46
Having the head rebuilt on my Case SC which naturally is costing more than I paid for the tractor but here is the question. Upon taking everything out of the way to remove the head, I noticed that there was not a thermostat. Did a 1947 Case SC come with a thermostat?
Thanks for any help or advice.
Cory
C. Amick
09-26-2006 09:17:17
 Re: CASE SC in reply to Cory Rusher, 09-25-2006 11:52:46
Depending on which one you buy, you may have to trim the thermostat flange a little to get it to fit in the hose. 180 degrees is the recommended running temperature.
jal-SD
09-26-2006 06:28:53
They are in the top rediator hose. Don't remember the # that we used, got it from NAPA. Had to drill a 3/16 hole in it so the water pump could by-pass, as the original had a hole & new one didn't. (My $0.02 worth. jal-SD)
JoelV
09-26-2006 04:22:22
Mine has one.
