De oil brake discs
Keith Alexander
12-09-2002 07:46:11
The differential seal on my 311b failed and gear oil has soaked my brake discs. Any ideas on how to clean them up?
dan
12-09-2002 17:50:25
 Re: de oil brake discs in reply to Keith Alexander, 12-09-2002 07:46:11
we steam them off at work and then sometimes use a sandblaster if they need it. I don't know about gasoline. I guess it would work but why risk it?
CASEPOWER
12-09-2002 12:56:55
I clean with gas then give them a light sandbasting in the blast cabinet. This ruffs them a little and gets rid of all the glaze. Larry's idea sounds good too.
Larry
12-09-2002 10:26:29
Brake cleaner would work,but it would probably take a lot of it to get the job done. I usually clean them up the best I can with gasoline. Then I set them out in the drive way and set fire to them. This will dry them out good and cook out any oil that has soaked into the lineings. Just be careful you don't set yourself on fire or your shop.
Zach
12-09-2002 12:31:11
 Re: Re: de oil brake discs in reply to Larry, 12-09-2002 10:26:29
guess i never thought of that. good idea. i will have to try that.
Zach
12-09-2002 09:28:20
How to clean the brakes???? you will probly have to get different brakes. you could try brake cleaner on them.
