LA case
JON
12-09-2002 07:04:26
Does anyone know if 26" or 34" tires were optional on a case LA or LAI Thanks.
Joel
12-09-2002 09:58:41
 Re: LA case in reply to JON, 12-09-2002 07:04:26
I have a 1944 LAI w/ 18.4.26 tires on it.
Bill Hires
12-09-2002 08:59:02
The "LA" and "LAI" parts catalog No. G210 lists these tire sizes, 14:00-28, 14:00-30, 15:00-30, 12:75-28, 18:00-26, 18:00-36 and 13:50-28
RobertTX
12-09-2002 07:42:34
A wide 26" wheel and tire was on the ricefield version of the LA. Think the correct tire was 18.4X26 (or 15X26 in the older tires). These use a different hub, will not go on a hub that had 30s on it. Not sure about 34s, the first time I am aware they were used was on the later 500 Diesel, around 1954. The early 500 had 30s like the standard LA wheel.
Richard
12-09-2002 09:53:50
 Re: Re: LA case in reply to RobertTX, 12-09-2002 07:42:34
Robert,
Do you mean the axle is different or is the cast wheel different? Are you the person who recently went to Kansas to pick up an LA?
CASEPOWER
12-09-2002 12:59:55
 Re: Re: Re: LA case in reply to Richard, 12-09-2002 09:53:50
The axles are the same. A friend just went from 26" to 30" just change them HEAVY HEAVY cast centers and what your toes and fingers..
Frank
12-09-2002 15:06:30
 Re: Re: Re: Re: LA case in reply to CASEPOWER, 12-09-2002 12:59:55
I just removed my centers to put weld on hubs on and the centers weighed 960# each.
Steve-MN
12-10-2002 15:59:14
 Re: Re: Re: Re: Re: LA case in reply to Frank, 12-09-2002 15:06:30
Frank,
I would also appreciate any info you might have on how you handled those monsters.
Thanks,
Steve
RobertTX.
12-10-2002 07:29:09
Frank, I have that project in my future. If you can give any pointers on handling and moving those babies, it would be appreciated.
Don L......... Frank, email me
12-10-2002 06:00:46
Frank....email me with a update..
Don L.
RobertTX
12-09-2002 10:45:48
The axle is the same (I beleive, I actually haven't checked the parts book to verify), but the cast hub the rim clamps onto is different. I have verified this in the parts book because all the dead ones I find here are ricefield and that wide 26 rim causes the tractor to be over the 83" width of my trailer. Yes, I did bring one in from Kansas recently, it must be me.
