Hi All,Well, I finally had a chance to go out today and mess around with the two project SCs that I'd been soaking for the last two weeks. The '45SC (the one with the head already off) is still stuck tight- even though the cylinders look pretty good. Before I tried turning over the '49SC, I pulled the hood and the valve cover so that I could make sure the valves were free. I oiled and tapped on all of them with a hammer, and all of the valves were free except for two- one on cylinder #1 and one on cylinder #2. After fiddling around with #1 for awhile, it popped back up and is now free. However, the valve on #2 is still stuck in the open position. The Marvel Mystery Oil that I was using to soak the pistons had leaked down in all of the cylinders except #1. By the end of the day I got the engine broken free by using the hand crank, but now I am afraid to turn it over very far since that one valve is now all the way open. The valve is down far enough now that the push rod is loose and can be removed- and it is slightly bent. Good thing I've got a spare. This tractor looks like I could possibly get it running if I could only free up this pesky valve and keep it from sticking again. Any ideas to try so that I don't have to pull the head? I've soaked and tapped and soaked & tapped- but this valve is only moving one direction... DOWN! I just hate to mess up a perfectly good head gasket, exhaust manifold gasket and waterpump gasket if there's a way to leave that head on. Thanks in advance, -Schotte
