Top degreasers
Jeb Mccranie
12-07-2002 13:22:09
In your opinion, what is the best engine degreaser. It must be safe on painted surfaces. Also, if anybody has any homemade degreasers, I would like to know how to make them. Again, it must not harm the paint.
Dan in Pa
12-11-2002 11:02:30
 Re: Top degreasers in reply to Jeb Mccranie, 12-07-2002 13:22:09
Jeb,I have been using gunk on my tractors after bringing them home. I buy it in the gallon cans, which will make 10 gallons cause you dilute it with 9 gallons of kerosene. I only cut it with 4 gallons for the real bad jobs.I apply it with an air nozzle sprayer, and the trick is to really let it soak .I have even left them go to the next day if they were really bad. Now together with hot or even cold pressure washing will do a great job on cleanen er up.I recommend removing the gen and covering up the mag or dist. I have never had a problem with it harming paint or anything else .
Oldfarmboy Jim
12-07-2002 20:51:13
The safest way I know of to degrease without harming paint, is to rent a pressure washer with a heating unit. HOT water under pressure will melt the grease, oil and dirt right off any tractor. There 's no chemicals to harm paint, rubber, or gaskets this way. Second best is to get a gallon of SIMPLE GREEN. Spray it full strength on the tough spots, let it sit thirty minutes, then repeat. Wait about fifteen minutes, then use one of those JETX (or similar) car washers putting more simple green in the detergent cup. Works great for me.
Good luck,
Jim
