Need help identifying loader tractor
Jim C
12-07-2002 12:52:35
I have, what seems to be a 430 utility (industrial version)??, I have talked to several people and have gotten different answers. Have not found any serial numbers yet. Did just get a manual for the 430 series, but my tractor has some significant differences. It has a real heavy loader that looks like it came from factory with it. The 3 pt. Eagle hitch is lifted by one of the loader control levers and it looks like all the hydraulics are coming from an external pump out in front of engine. The front grill has round holes rather than the typical screen type grills. The hood is 3 pcs rather than 2. It has a hydraulic cylinder for the steering but it mounts behind front axle, not in front of. Can any of you Case buffs give me a heads up to what this sounds like and where can I get the correct manual? I can send pics if someone is interested in helping. Thanks.
John H
12-07-2002 13:05:20
 Re: Need help identifying loader tractor in reply to Jim C, 12-07-2002 12:52:35
Is the serial number plate not on the dash? Someone else may know if its someplace else if its missing. Thanks.
Jim Yadon
12-07-2002 15:15:31
 Re: Re: Need help identifying loader tractor in reply to John H, 12-07-2002 13:05:20
I was reading your post and it sounds pretty much just like the 430 case I have. Mine is a 1963 model per serial number which was located to the right of the steering wheel on the dash. The serial number indicates that the tractor was just a 430 not a utility. It also has a case 22 loader on it. But it looks like it was a special custom order the way everything looks and the everything fits together. I just recently bought myself. My tractor has the holes in the grill just like yours. Mine has the two panel hood. Large panel and the nose cone. No three point but has a weight box. Doesn't have pto either. My tractors power steering cylinder is on the front top side of the front axle. I am learning how mine goes together right now. Be sure and check your front spindle bearings and king pin and bushings. Also the thrust bearing. Everything else on my tractor pretty good shape except for these items and the were shot. Hopes this helps and feel free if you have any questions. JimY.
Jim C
12-08-2002 14:03:02
 Re: Re: Re: Need help identifying loader tractor in reply to Jim Yadon, 12-07-2002 15:15:31
To Jim Y.
I was wrong. My steering cylinder is mounted in front of the axle, not in the rear.
Jim C
Jim C
12-08-2002 08:42:16
Thanks guys for the input. No, the serial number plate is gone. I am hoping (wishing) that they may have another one tucked away somewhere on the tractor. Hey Jim Y. what does your dash look like? my instruments are all in one cluster, not separate gauges like many of the 430`s I have seen. What is your e-mail address maybe we can swap some pics, I would like to see your 430.
Thanks again.
Jim C
