Will the heads off a 730 fit my 400
D Brown
12-05-2002 22:47:30
does any one know if a 730 deisel has the energy cells in the head and will the heads off of it fit my 400 deisel?
Jim M
12-07-2002 02:54:01
 Re: will the heads off a 730 fit my 400 in reply to D Brown, 12-05-2002 22:47:30
I don't think they will work. The bolt pattern chganged when they went to the 30 series
Scott KY
12-06-2002 16:20:31
Don't know for sure but the later 400 Super diesel had a 267 cu. in. engine also.
Slowpoke
12-05-2002 23:30:37
My book says the Model 400 Series diesel has a 4x5 b&s, and is 251 cu. in.. The Model 730 Series diesel has a 4-1/8 x 5 b&s and is 267 cu.in
Ask a Case/IH dealer to look up the part #s on the computer, to see if they are the same. He should have the info, even if parts are not available.
The head may fit the block, but it could have a different manifold setup. Probably best bet would be to compare side by side.
