D hydraulics
dbb62
12-05-2002 18:13:01
Anyone got an opinion on how to add hydraulics to a 1949 standard D? It's a good old tractor, but would double it's usefulness with a set of rear remotes. I know these were available on later models, but don't know if they would fit our tractor, etc.
Any ideas would be appreciated.
North M
12-06-2002 06:21:16
 Re: D hydraulics in reply to dbb62, 12-05-2002 18:13:01
My first thought would be to look around for a set of hydraulics off of a D or DC because they will both fit your tractor. I have a set on my D and they work well. It would also give the factory look of being neat and clean. The other idea I would use is belt driven off of the crankshaft to give you live hydraulics . Perhaps salvageing a set off of a wrecked swather would give you all the parts for the conversion. They do have PTO pumps but you then lose the use of your PTO driven equipment. Your right in that with hydraulics your tractor will be twice more useful.
Hoosier
12-08-2002 19:13:46
 Re: Re: D hydraulics in reply to North M, 12-06-2002 06:21:16
We put live hyd on SC by installing pump between mag and engine. The pump came off a case SP12 combine. Bolted right up. We used it to add power steering. Should work same way on a DC. Good luck.
Steven@nd
12-05-2002 18:32:48
Never done it on a Case, but have added hydraulics to a couple Farmalls without them. One is on a Farmall A that runs off the belt pulley (not live). Works good. A friend of mine has an H with live hydraulics that are chain driven from the crankshaft. This would work fine with a belt, he is running 2500 psi to run a loader with his and never does full throttle work. See pics for ideas.
third party image
third party image
third party image
third party image
