Old paint on tires
SheldonMT
12-05-2002 17:35:28
Do any of yous guys have a trick to taking quite a bit if old (sprayed on) paint off a good rear tire. The guy that I got it from was not carefull at all when painting as he was replacing with all new tires. But this one is a really decent traction tire , with alot of use lift in it. Thanks for any help. SheldonMT
Dan In Pa
12-11-2002 11:52:32
 Re: Old paint on tires in reply to SheldonMT, 12-05-2002 17:35:28
I would try spraying some easyoff ovencleaner on that tire, only if it's off the tractor cause that stuff really does a job on removing paint. I use it all the time to remove paint on rims ,wheels and all sorts of things that need paint removal. the main ingredient is lye so be carefull and wear protective eyewear and old clothes as that stuff is very nasty. spray it on let it soak for about 1hr and wash off. Then repeat if necessary. Good Luck.
Larry from Maryland
12-06-2002 16:13:15
I just sanded it right off with a vibrator sander.
MARK
12-06-2002 15:11:53
I've used good heavy (thick) paint stripper and washed it off with a power washer. You can use a brass bristle brush to loosen up the heavy or tough spots. I have done this several times with good luck. Some people just can't seem to mask off the tires when painting.
Irv
12-06-2002 03:14:11
I've used acetone on tires to clean up after a fresh paint job, even after it was dry, but I'm not sure about old paint
Richard
12-05-2002 19:04:43
brakefluid will take paint off or paint striper. brakefluid is good for rubber not sure about paint striper.
dbb62
12-05-2002 18:07:11
Don't know how to get the paint off, but have read several posts from guys who swear by Miller's tire paint. www.millertire.com
They say it will cover just about anything and make old tires look new for what it's worth.
