Need dc help!!!!!!!!
Tom Bush
12-03-2002 19:15:13
I know you guys can answer these simple questionsso here goes,
1. Where is the "id"# for the tractor at?
2. I need a water pump,where's the best place to get one?
3. How do you check the engine oil?(Where)
4. The starter will not engage the motor all the time when you try to start it,seems to spin ok just wont engage the flywheel..... .there is a 1/2inch space between the block and the starter is this right? Seems like it should be flush with the block. Thanks
Frank
12-04-2002 22:19:49
 Re: need dc help!!!!!!!! in reply to Tom Bush, 12-03-2002 19:15:13
There should be a cork oring type gasket about 1/2 inch wide between the starter and the housing to keep out moisture and keep in oil.
Tom Bush
12-05-2002 17:28:51
 Re: Re: need dc help!!!!!!!! in reply to Frank, 12-04-2002 22:19:49
Thanks Frank,I appreciate the help !!!!! !!!
Tom Bush
12-05-2002 17:31:16
 Re: Re: need dc help!!!!!!!! in reply to Don L., 12-04-2002 13:40:32
Thanks Don L,I appreciate the info.I'm sure I'll be calling you!!!!!
Dave_D
12-04-2002 13:28:33
I don't think the starter should have that space. The starter is held in place with one bolt from the top. I would undo it, and check for are worn starter or flywheel.
Good Luck
- dave
Tom Bush
12-05-2002 17:37:25
 Re: Re: need dc help!!!!!!!! in reply to Dave_D, 12-04-2002 13:28:33
Thanks for the info,I think your right,I've checked that bolt-in-line with the hole but it just doesn't seem right.But I'm going to take the starter to an electric shop,let them check it out,and yes the flywheel is worn,but it doesn't seem to be that bad,but maybe it is.Thanks again!
Tom Bush
12-05-2002 17:40:19
 Re: Re: need dc help!!!!!!!! in reply to North M, 12-04-2002 07:29:26
Ok, thanks for the info North M and I'll be sure to check out that site too!!!!! !
Paul F
12-04-2002 06:14:43
In addition to data plate on the instrument panel the serial number is on the left side of the flange at the rear of the motor.
There should be three drains (or plugs) on the right side of the oil pan. The one on bottom edge is obviously the drain. Somewhat forward and further up the side are two more. The highest is the level for you oil. Fill until it runs out. The slightly lower one is for dual fuel tractors. You were supposed to drain it down to that level and refill after everydays use (Basically you replaced about a quart every day.)
Tom Bush
12-05-2002 17:44:36
 Re: Re: need dc help!!!!!!!! in reply to Paul F, 12-04-2002 06:14:43
Wow!!!!! ! that was neat info about the oil(with the dual fuel) I would never have guessed that!The info about the serial # was much appreciated too!!!!! !!!! Thanks
Lucas
12-03-2002 19:33:38
The serial number should be on the dash by the steering wheel. If a DC is the same as an SC, then to check the oil remove the top pipe plug in the oil pan and see if oil runs out. If the oil is level with the bottom of the hole then it is OK. It sounds like your starter might need a bendix. My MM ZTU does the same thing. Lucas
Tom Bush
12-05-2002 17:48:29
 Re: Re: need dc help!!!!!!!! in reply to Lucas, 12-03-2002 19:33:38
Lucas,Thanks for the info,I thought the same thing about the "bendix "too but it has a "worm" gear type????? ???? I'm gonna take it to an electic shop
