Piston and sleeve sets- are they matched?
Mike Schotte
12-02-2002 16:19:09
Hi All,
I was watching this Ebay auction (which ended last night) for the DC Case piston and sleeve set.
If you look closely at the auction photos, there are dots painted on top of the pistons. One piston has 4 dots, the other has 3 dots, etc.
Any idea why these are marked this way? Are the pistons and the wet sleeves matched to each other? I wouldn't think it would matter until they had been run in an engine.
I also can't see why there would be any difference which sleeve got mounted in which cylinder location.
Just curious... does anybody know?
-Schotte
Elmer
12-02-2002 17:08:14
 Re: Piston and sleeve sets- are they matched? in reply to Mike Schotte, 12-02-2002 16:19:09
Hey Mike, i have bought engine parts that were not matched. I would not think it matters too much, until like you said they are run in an engine. But then i have seen people buy used sleeves and pisto that were mismatched and ran them with no trouble. It might have something to do with excess clearances too.
Mike Schotte
12-02-2002 17:12:42
 Re: Re: Piston and sleeve sets- are they matched? in reply to Elmer, 12-02-2002 17:08:14
Thanks, Elmer.
There was a used set of DC sleeves and pistons that also sold on Ebay last week- but I figured there would be no way of knowing exactly what you were getting...
Could have just been some expensive paper weights. (grin)
-Schotte
CASEPOWER
12-02-2002 18:10:11
 Re: Re: Re: Piston and sleeve sets- are they matched? in reply to Mike Schotte, 12-02-2002 17:12:42
Come on Mike them were mine. I am going from 3-7/8 to 4-1/2 and just don't need them it was not because They were warn out. There Case they still have 50 years left. Didn't you look at my feedback?? I can't say that I blame you though. It's hard to trustsomeone over the net..CASEPOWER (AKA casefordson on e-bay)
Craig
12-06-2002 08:50:09
 Re: Re: Re: Re: Piston and sleeve sets- are they matched? in reply to CASEPOWER, 12-02-2002 18:10:11
Hey CASEPOWER, how are you putting 4.5 inch pistons in a DC?
RobertTX
12-03-2002 06:41:03
I knew they were yours, would not have bid on them otherwise. Somebody needed them worse than I did. For my purposes of bringing a 50 to 70 year old tractor back to service, used pistons and sleeves are just fine. Ideally, new ones would be matched so that the clearance would be optimum. The last step in finishing is honing the cylinder (or sleeve), which is not a dimension set process. There are variations then in the sleeve and piston actual sizes, matching them to get proper clearance keeps everything working best.
Mike Schotte
12-03-2002 10:16:03
 Re: Re: Re: Re: Re: Piston and sleeve sets- are they matched? in reply to RobertTX, 12-03-2002 06:41:03
Hey Robert,
I just picked up an original sales brochure for CC, DC,or SC aftermarket 4" diameter "Add-POW'R" aluminum pistons made by M & W.
According to the text of the brochure:
"Each piston has been matched to it's own individual sleeve and marked to make sure each piston and sleeve is mated properly when being installed."
Says they will add 6 or more horsepower to your CASE tractor.
Talk to you later, -Schotte
Don O
12-02-2002 19:58:20
How are you puting 4.5 in a dc? What are thay out of? How much hp do you think you will get?
Mike Schotte
12-02-2002 18:17:18
Oops... sorry CASEPOWER! Didn't realize that was your auction.
I was in no way trying to say anything about your merchandise- but as you know, trying to measure engine parts over the 'Net can get a bit chancy.
I noticed that RobertTX bid on those as well, so it's lucky that we didn't butt heads on them!
I figured there's no point in going after a set until I find out that I need 'em.
Good luck on the auctions, and thanks for being a parts source for us Case folks...
-Schotte
