What engine oil?
Steve-MN
12-01-2002 17:04:43
I've got a 49 LA & am running SAE 30 or 20 with an API service rating of SL,SJ. Says it also meets requirements for all earlier model gas vehicles where SG or SH is specified. Does not say anything about non-detergent(low-ash) & these specs mean nothing to me. Was wondering if this is ok. What do you guys run in your old Case engines?
Thanks,
Steve
Jeremy
12-03-2002 16:56:12
 Re: What engine oil? in reply to Steve-MN, 12-01-2002 17:04:43
I run Shell Rotella in all of my equipment. Better for cold and hot weather. Plus Rotella can't be beat. I think the oil you are running is plenty ample for your LA. I would only run the SAE 20 in the winter.
Jeremy
Steve-MN
12-04-2002 17:56:24
 Re: Re: What engine oil? in reply to Jeremy, 12-03-2002 16:56:12
Jeremy,
Thanks for the info. I switched to 20 wt 4 wks ago & dumped my 30 wt. I just don't know if it's non-detergent. I'll try your 30 wt next summer. Have a JD dealer 1 mile away & they told me to run modern 10W30. That's what they recommend to all antiquer's. I have my doubts. I work at Cat & the engine metalurgists could not tell me what to put in, but they definitely told me not to use detergent oil. The old metal can not handle contamination over time that is kept in suspension. It needs to settle out. Use the non-detergent(low-ash) if I can find it. They also said to be leary of multi-vis in old engines.
I called Case this week & they carry the low-ash single grade for a high price & they recommend it for all old tractors(unlike JD-hmmmmm--JD must like the parts business:) but Case is a hoof from here & I want to buy something close by.
Thanks for the input,
Steve
