Db995 hydraulic problems
mark
11-29-2002 13:46:41
I have no hydraulic pressure at my three point or loader on my 995. I have already went throught the obvious things, filter, oil ect.. I have rebuilt the control valve and it bench tested ok. I have 2600 psi at the pump. Is it possible the relief valve on the pump is allowing too much pressure to the control valve? The relief valve on the control valve is opening properly at 2500psi. My manuals never discuss too much pressure from the pump, just too little.
Elmer
11-29-2002 14:50:38
 Re: db995 hydraulic problems in reply to mark, 11-29-2002 13:46:41
Are you operating the loader by a 3 way valve on the left side of the tractor? You could have a cracked line from the control valve to the lift cylinder which would effect the loader as well.
mark
11-29-2002 15:59:52
 Re: Re: db995 hydraulic problems in reply to Elmer, 11-29-2002 14:50:38
Yes I am running the loader from the three way valve. How can you access that line from the control valve?
