Dc4
roy
11-21-2002 22:39:16
bottom of case were chain&sprockets are popped a hole about 4 inchs square below chain .dont know what happened but am trying to repair.removed pto shaft and hyd pump. removed 10bolts but case will still not move.am i missing anything inside.cant find any manuals for this area. need help please.
CASEPOWER
11-22-2002 05:51:55
 Re: dc4 in reply to roy, 11-21-2002 22:39:16
You have to remove the transmission top and steering box. Then remove the inspection cover on the side of the bell housing and remove the cap and nut from the end of the pto shaft. You will have to remove the hood and gas tank to get the top off. The PTO shaft comes out with the rear cover. It sounds like a bad job, but is not to bad at all.
