I bought two J. I. Case Vac tricycle tractors.
Nicholaus Sowde
11-21-2002 15:21:57
I bought two J. I. Case Vac tricycle tractors and need some parts. The tractors serial numbers are Vac 535123913 1949 and Vac 527267412 1948. I need four of the coil springs that go underneath your rod that goes back to your brake housing. I also need four regular springs that hold tension on your brake pedals. I think there should be one on each side. Thanks alot
Don L.
11-22-2002 05:35:20
 Re: I bought two J. I. Case Vac tricycle tractors. in reply to Nicholaus Sowder, 11-21-2002 15:21:57
You need a VT4003 spring. would best to measure the distance needed , and get a new spring from NAPA .
Don L.
