LA Case Engine
Howard H.
11-20-2002 22:03:20
Hi Ya'll,
I saw an LA Case with a blown Detroit engine in it the other day. It sure sounded keen! :)
I was just wondering the story on who did those conversions and what engines will replace the standard engine that came from Case.
Were there other engines that would fit into an LA without much trouble?
Thanks a lot for any info,
Howard H.
Ron
11-21-2002 19:16:14
 Re: LA Case Engine in reply to Howard H., 11-20-2002 22:03:20
I saw one of those the other day. Did not know there was such a thing until I saw it with my own eyes. This one was stuck. It was for sale but he wanted too much $ for it----- 4500.00. I bet one would make a stout puller.
Steven@nd
11-21-2002 05:50:23
There was I think a blacksmith shop that did the GM diesel conversions. Last summer I ran an LA with a 4-71 Detroit in it. Tons of fun! I believe the LA's with the Detroits in them are allowed to pull in the antique class because it was a dealer option. Someone will correct me if I'm wrong.
jd730
11-21-2002 17:37:41
 Re: Re: LA Case Engine in reply to Steven@nd, 11-21-2002 05:50:23
Steven The conversion was a Detroit Diesel Company kit. I'm sure some dealers did the conversion for their customers but I don't think it was ever approved by Case. Egging Cab Co. in Gurley Neb. used to do the conversions. The guy who bought my 3/71 LA said his dad did a lot of the coversions in the 50s when he worked for a Detroit shop in Kansas. He gave me copies of the original instuction bulletins.Also shows installation for Farmall Ms and F30s. Later Bill
Howard H.
11-22-2002 07:22:31
 Re: Re: Re: LA Case Engine in reply to jd730, 11-21-2002 17:37:41
Hi Fellows,
Thanks for the info...
Was the Detroit engine a fairly common engine by itself? Would that engine alone fit into an LA or are there special LA fittings or adapter brackets that are also needed?
Also, a friend of mine was talking about a 4 cylinder Cummins that also fit into an LA... What is the story on that engine? Apparently, it was only about 40 horsepower! I didn't know Cummins even made an engine that small...
(My only Cummins is the 360hp reman in my 895 Versatile)...
Thanks again for any info!
Howard H.
jd730
11-22-2002 21:07:15
 Re: Re: Re: Re: LA Case Engine in reply to Howard H., 11-22-2002 07:22:31
Howard The conversion requires a bellhousing adapter plate a special front mount and a special transmission input shaft. The early conversions kept the original wet clutch setup. In the revised bulletin it says to change to a dry clutch. The LA I had still had the wet clutch. The bellhousing had a dipstick installed to maintain the correct oil level.The original LA gas engine had a hole in the crankshaft that supplied oil to the clutch. The detroit crank was not setup that way so they made the bellhousing a seperate resevoir. Hope this sheds some light on the conversion for you. Later Bill
Steven@nd
11-22-2002 10:30:49
I know the Detroit engine was in other tractors from the factory - Oliver Super 99, 990, 995 Lugmatic, 1900, 1950. Also the JD 435 had a little detroit in it.
Detroit 2-cycle diesels are more common in Over The Road trucks.
I suspect there would be adapter plates, etc. to put a Detroit in any tractor that didn't come with it factory.
Steven@nd
11-22-2002 06:37:20
Thanks, Bill. I always know you have the right information on them. I would like to see the instructions for the Farmall M sometime. I think I'm going to have an extra W-9 in need of an engine before too long, Detroit would be a good engine in one of those too...
jd730
11-22-2002 21:14:09
 Re: Re: Re: Re: LA Case Engine in reply to Steven@nd, 11-22-2002 06:37:20
Steven There was a W9 for sale on the auction a couple of years ago that had a Detroit in it. It was in Texas. I have info on the W6 conversion but nothing on a W9. Later Bill
