When did the SC get hydraulics?
Steven@nd
11-20-2002 19:18:03
Just wondering what year the hydraulics were available and if it is possible to add them to a 44 model? Thanks!
Larry
11-21-2002 16:17:54
 Re: When did the SC get hydraulics? in reply to Steven@nd, 11-20-2002 19:18:03
My 49 DC has the factory hydraulics on it. I don,t see any reason why you could not change the PTO assembly and have hydraulics on a DC or SC. According to my parts book you would have to find a #03004AB1 PTO shaft and and a #3775AA housing with the pump, valve, chain, linkage, and accessories to add the hydraulics to a DC.
Mike Schotte
11-20-2002 19:57:09
Hey Steven,
I always thought the SCs got hyrdaulics in 1949, because my '49 has them...and if you look at the production number listings on YTMAG- 1949 was one of the biggest selling years for the SC.
However, I've heard other people say they got them in 1950. Perhaps my tractor was retrofitted... I don't know. My '49 DC3 doesn't have hydraulics, and I always wondered why not.
With regards to your question about bolting up the Case hydraulic items onto an older model- I've pondered that particular question as well. Perhaps all you'd have to do is change out the P.T.O. housing and bolt on the hydraulic pump??
Maybe Don L. or one of the others will enlighten us.
-Schotte
Don L.
11-22-2002 05:29:55
 Re: Re: When did the SC get hydraulics? in reply to Mike Schotte, 11-20-2002 19:57:09
1949 was the first year for hyds. A SC can be converted to hyds, using the backhousing off one that does and the pto shaft from one.
Don L.
Steven@nd
11-22-2002 06:34:23
 Re: Re: Re: When did the SC get hydraulics? in reply to Don L., 11-22-2002 05:29:55
What do you mean by "back housing" does that mean the whole rearend case? Or just the PTO housing and shaft?
Thanks!
Steven@nd
11-21-2002 05:48:10
Perhaps the lack of a hydraulic system is why the SC and DC sold quite a bit less than the H and M Farmall? I know the belly pump on the Farmalls isn't all that great by today's standards, but it works fine for the smaller stuff like mowing and raking.
Would be nifty if I could get hydraulics by changing out the PTO unit. Otherwise I will probably try to set something up to run belt driven from the crankshaft or belt pulley.
Larry
11-21-2002 16:29:19
 Re: Re: Re: When did the SC get hydraulics? in reply to Steven@nd, 11-21-2002 05:48:10
Steven, I thought that I was the only one to be brave enough to have both Case and Farmall tractors. I have a restored 49 Case DC, 47 Farmall H, 48 Farmall H, and a 57 Farmall 350. Am in the process of restoring the 47 H at this time.
case poor in pa
11-23-2002 15:21:51
 Re: Re: Re: Re: When did the SC get hydraulics? in reply to Larry, 11-21-2002 16:29:19
i always keep a I H around so i have something to pull for my cases .. 460 works good for that quite a lot of dead rollin wheight
Steven@nd
11-22-2002 06:33:46
I buy what I can afford. Would like to get an Oliver Super 77 or 88 diesel in the fleet someday. I have a 42 Farmall H, 54 Super MTA, 4? Farmall A, 46 W-9, 44 SC, hoping to add a Farmall B and C to the line too.
I got into the Case because a friend was selling it and I got it at a decent price. It needs some work, but nothing too major.
