Oil for Case-o-matic
PA Steve
03-19-2006 05:55:00
I"m sure someone has discussed this by now but I"m wondering what the best oil for the hydraulics on a Case-o-matic is. My manual states 10 weight motor oil. Is there a better choice. 10 weight is hard to find sometimes. Thanks, Steve
PA Steve
03-21-2006 09:39:07
 Re: Oil for Case-o-matic in reply to PA Steve, 03-19-2006 05:55:00
Thanks guys, sounds like ATF is a good way to go. Steve
Jim McVay
03-21-2006 02:57:52
Use DEXTRON ATF.
old
03-19-2006 12:26:38
On my 800 I called the case dealer and asked about the hyd oil to use and the guy said any good hyd fluid works just fine. In my case that was Oriellys 303 universal hyd fluid.
K-Mo
03-19-2006 11:39:35
On my 630, the Case-O-Matic and remote hydraulics are the same reservoir. I use the farm store universal Hydraulic/Transmission type oil in everthing because if you attach different tractors to the same hydraulic implements it all gets mixed together anyway. My 630 manual specifies 10W or Type A transmission fluid.
K-Mo
