Does LP help or hurt the value of a 730?
ryan
11-20-2002 15:02:50
My grandfather has a 730 LP with a mounted picker. While attempting to research a value for him I have been unable to determine whether or not the fact that it is LP hurts or helps the value. Thoughts?
Tom in Mo.
11-20-2002 19:07:05
 Re: Does LP help or hurt the value of a 730? in reply to ryan, 11-20-2002 15:02:50
A collector usually likes the rarity or uniqueness of an LP. A worker will not want the LP because of the difficulty in fueling.
ryan
11-20-2002 20:03:58
 Re: Re: Does LP help or hurt the value of a 730? in reply to Tom in Mo., 11-20-2002 19:07:05
how rare was LP? About what percentage of tractors that had the option were made LP?
Tom in Mo.
11-21-2002 16:21:59
 Re: Re: Re: Does LP help or hurt the value of a 730? in reply to ryan, 11-20-2002 20:03:58
I don't know the numbers on how many were built. I do know that in the southern half of the US they were common during the late fifties and sixties. Propane sold for about a nickel a gallon then so it was the 'all fuel alternative' to cheap fuel. I have heard of a Deere model, maybe others, that sold more propane tractors than gasoline tractors. Diesel was coming on strong then and eventually outsold everything due to ease of fueling and maintenance. Propane is a pain in the butt unless everything is just right; no leaks and proper filling equipment.
I have a 1965 Case 830 CK LPG that is gonna be ready to go in the spring. It has been more expensive than it's worth but that is normal in the life of a cast iron nut.
Jim P
11-21-2002 21:59:16
 Re: Re: Re: Re: Does LP help or hurt the value of a 730? in reply to Tom in Mo., 11-21-2002 16:21:59
In my county in the late 1940's - mid 1960's M&M had more LP's than any other CO. I have on LP a 1958 900 Case and have had 4 other case LP's . The only pain I had was when I run out of fuel at the far end of the field.
