DC cluch problem
Dale L
03-18-2006 17:30:53
We just put the engine back on the DC and we had to set up the clutch. Well now I can't get the pin that I had to push in to adjust the clutch to pop back out. Does anyone have a trick to get the pin to pop back out? We've been messing around all afternoon with no luck!!!
Case1950
03-21-2006 18:41:56
 Re: DC cluch problem in reply to Dale L , 03-18-2006 17:30:53
I don't know if you solved your problem yet, but I have the same problem. I was adjusting my clutch and the button wouldn't come back out. I am going to try and use a magnet to get it to come back out.
Case1950
Dale L
03-23-2006 19:47:07
 Re: DC cluch problem in reply to Case1950, 03-21-2006 18:41:56
I went out to the shop the next day and wiggled it with a srewdriver and it popped right out.I think letting it sit over nite in penatrating oil must have done the trick.
wilson
03-18-2006 19:54:35
check to determin that there is not another pin that is already poped out around the clutch that you are not seeing
