Case magneto ?
T.J.-N.J.
11-14-2002 06:10:48
Hi I have a 52 SI with a loader on it and am getting it ready for the snow season, It has lost its spark again I go through this every year,taking the mag apart and fiddling with it. I was wondering if there was a distributer that will easily replace a mag on an S or SC from another series perhaps on from a Vac or another model? Thanks T.J.
RAR/IA
11-14-2002 17:08:11
 Re: Case magneto ? in reply to T.J.-N.J., 11-14-2002 06:10:48
Watch out for direction of rotation so the distributor is advancing and not retarding when running. Especially if using IH distributors. Some are CW and others CCW.
C. Amick
11-14-2002 10:00:43
A distributor from a Farmall Cub, Super A, Super C and probably other larger Farmalls will work. They are horizontal distributors. They fit pretty tight, but will work. I just put one on my Case SC. You will need to get the whole assembly, not just the distributor. You will need the gear box that the distributor attaches to complete with the front shaft.
Mike Schotte
11-14-2002 09:16:18
Hi T.J.,
I haven't converted any of my tractors to a distributor- but I do run an International Harvester H4 magneto on my Case SC.
Rebuild parts are readily available on the web, or I can give you the NAPA part numbers for most things you'll ever need to buy to keep it running. This is the unit that keeps me going until the day that we can buy replacement parts for the Case/Slick magnetos!
Regards, -Schotte
jal-SD
11-14-2002 08:32:04
We put a Delco battery ignition system off of an Allis Chalmers on my '44 SC row crop. (Got it from a salvage yard-don't remember if it was off of a WC or WD.) It has to be the one that the distributor cap is upright (not horizontal) in order to have the needed clearance. Don't know anything about SI's, but assume the clearance will be the same.
I've also seen these same systems on H Farmalls, probably used on M's & Super C's & others as well, because the guys @ my C-IH dealership know just what I want for points, etc. when I ask them for the Delco stuff. It works in the AC distributor that I've got on my SC. I just got new rotor, points, condenser & cap this fall, so I know stuff is still available.
If I remember right, the distributor runs counter clockwise, so you have to plug the wires in the right order, opposite of what you had, but that's not a problem. Been a long time since we did that, so don't remember all the details, but its worked for more than ten years. I do remember that it bolts right up to the housing where the mag bolts on. (My $0.02 worth. jal-SD)
