Clunk...Clunk... Clunk.
Robert P
11-12-2002 18:16:13
Last week I took out my newly acquired CASE VAC for a ride. As the left rear wheel turned I noticed a low rythmic clunking noise. What could be the problem ? Otherwise the old machine is running fine, a great hobby this tractor stuff.
bob
11-20-2002 19:20:49
 Re: Clunk...Clunk... Clunk. in reply to Robert P, 11-12-2002 18:16:13
my 730 did that but i figgered out later i had my ear to close to the tire tread. only heard it when my ear was to close to the ribs on the tire put the fenders on cured it ..easier on my ears to.... haha
S.A. Beatty
11-17-2002 06:10:13
Split your rearend and check your bull gears, you may fined a missing or chipped gear tooth. My VAC had a serious clunk in it and thats what it was. Keep me informed.
Sam (no expert)
Brandon
11-12-2002 19:13:39
It sounds like you need to tighten the bolts that hold the rim to the center hub. When one or more get loose, they can make a sound like that as the rim bangs back and forth.
Good luck!
Brandon
Robert P
11-17-2002 06:56:43
 Re: Re: Clunk...Clunk... Clunk. in reply to Brandon, 11-12-2002 19:13:39
Brandon was right, I found that there was some slippage between the rim and the center hub. I tightened the bolts and there is an improvement, also found that the rims are in bad condition. Thanks for the hint.
Bret
11-15-2002 05:17:16
Also- if it's got wheeel weights check to make sure they're tight. One of my VACs had the same noise until I tightened the bolts up.
