Sixteen year old needs help with buying a Case VAC
Stephen G
11-12-2002 03:58:58
Hi my name is Stephen G Im sixteen years old , and am loking at a Case VAC with a loader . Is there any weak points to look for on these tractors ? Also what would it be worth if it was painted up like new with the loader in good shape and fair rubber with wheel weights all the way around and tire chains . Im new at the Case tractors I have more John Deeres. Thank you Stephen G
John M.
11-16-2002 22:27:49
 Re: sixteen year old needs help with buying a Case VAC in reply to Stephen G, 11-12-2002 03:58:58
Hope you find no cracks in the block as someone mentioned. I decided to change the damaged copper gas line on my '53 VAC 14, so I removed the carb, and air filter. I discovered a dirty piece of sheet metal covering an 8" long weld. The metal blended in with the block and was held by the bolts from the air filter. Luckily, it doesn't leak. VAC is a nice little tractor. Good luck with yours. John
BLR
11-12-2002 22:40:15
I have a VA with a loader, and the biggest problem I have is the tractor gets light in the back end if you pick up a load. I haven't added weight or fluid yet but probably will add at least one of them. Be careful on any side hill if you're carrying a load. The hydraulics are powered by the stock engine driven pump with a four spool open center valve between the pump and eagle hitch. The four spool valve allows a hydraulic bucket, rear remote hook ups, with one valve to spare. Also, the VA series hydraulic system is designed to operate at ~800 psi and I have seen instances where people have overloaded the system and sheared off the cam gear. Consider setting your loader valve relief to release below 800 psi. Mine releases at 450 psi, and I can lift more than the tractor needs to. Consider the hydraulics and front end issues others have discussed, and you should have a nice light duty loader tractor that will stack up well against similarly equiped small tractors of that vintage.
Marty
11-12-2002 14:11:38
I have a 1951 VAO which has a front pump to drive the three point, but the PTO is clutch activated. I think you will find yours is the same. I would check the front end carefully also, since it is light duty and the loader could add wear to the suspension. Mine has lots of spit, since it was only ever used to remove snow and grade a 100 foot lane. The live 3 pt. is a bonus over the grey machines of the era! Enjoy but be careful, their power is deceiving.
TIM
11-12-2002 08:05:56
FOR WEAK POINTS YOU SHOULD CHECK OVER THE FRONT END CLOSELY IF IT HAS A LOADER ON IT AND ALSO VAC HAD PROBLEMS WITH THE ENGINE BLOCKS CRACKING SO YOU MIGHT WANT TO LOOK IT OVER GOOD FOR CRACKS OR WELD MARKS. PROBABLY BE WORTH ABOUT 1500 TO 2000 ALL FIXED UP. TIM
Stephen G
11-12-2002 05:35:41
Sory I forgot to mention it is in great mechanical condition , and is a 1951 , with three point hitch , live hydraulics , and live PTO . Thanks again Stephen G
Les...fortunate
11-12-2002 10:36:07
 Re: Re: sixteen year old needs help with buying a Case VAC in reply to Stephen G, 11-12-2002 05:35:41
I don't question what Tim said. I do question your saying a '51 has "live hydraulics and PTO". How did it get them?
TIM
11-15-2002 11:16:03
 Re: Re: Re: sixteen year old needs help with buying a Case VAC in reply to Les...fortunate, 11-12-2002 10:36:07
THESE TRACTORS DID COME WITH LIVE HYDRAULICS BUT NOT LIVE PTO. FOR LIVE HYDRAULICS IT SHOULD HAVE A PUMP ON THE RIGHT FRONT SIDE OF THE ENGINE, IF THERE IS NO PUMP IT SHOULD HAVE A METAL CAP OVER THE HOLE.
Stephen G
11-12-2002 12:48:52
I have not seen the tractor yet , I am going to see it tonight or tomorrow I was told that it has live hydraulics and PTO ? he gave me the serial number , 5571870 . Is he mistaken ? Is it not posible for this tractor ? Thanks . Stephen G
Marty
11-12-2002 14:19:03
 Re: Re: Re: Re: sixteen year old needs help with buying a Case VAC in reply to Stephen G, 11-12-2002 12:48:52
The way you have written 'live hydraulics and PTO' do not mean the PTO is live..and it likely isn't unless someone added major mod's. None the less a clutch driven PTO is more than satisfactory for a machine of this age and design. It does not limit the functionality of a chore tractor unless you are doing a whopping pile of snow blowing in close quarters. Tractors of this size and vintage are intended for small acreage and will suffice for this type of use. My VAC doesn't have a three point so you are one step ahead of me there!
