motor OH cost
4 R's
03-18-2006 09:33:15
new radiator and still motor running hot on a 4890. going to try and put some liquid glass into the radiator today. anyone have an idea of how much $ would be involved on an OH? motor sounds good just runs little warmer than i would like.
dwag
03-18-2006 16:50:25
 Re: motor OH cost in reply to 4 R's, 03-18-2006 09:33:15
Does she "push water"?
4 R's
03-18-2006 18:40:41
 Re: motor OH cost in reply to dwag, 03-18-2006 16:50:25
theres a little pin whole on the side of the block but just a little motor oil comes out every once in a while
old
03-18-2006 14:14:37
Have you done a good/complete cooling system flush?? I had the same sort of problem on an Oliver 77 till I drain it and then filled it with vinagar and ran it till good and hot, let it cool and then flushed it with a garden hose and let the hose run for about and hour. I hooked the hose in to the block drain so it would back flush. The tractors hasn't got hot since and that was 3 years ago.
4435
03-18-2006 12:32:11
Have you installed a known good temp guage? Manual tube. Tom
4 R's
03-18-2006 13:42:32
 Re: motor OH cost in reply to 4435, 03-18-2006 12:32:11
i have one installed, runs up to 220 in harder conditions.
Dennis/Ohio
03-19-2006 16:55:44
 Re: motor OH cost in reply to 4 R's, 03-18-2006 13:42:32
On my gas engine the temperture sensor bulb is in the head. I think that make mine show a higher temp. Seems head temp would be higher than block.
Old Rusty
03-18-2006 14:25:56
220 will not hurt it any. With a 7lb radiator cap it will not boil with plain water in it till 343deg and if you run 50/50 anti freeze and water it will go above 250 with out boiling at sea level. As long as exhaust temp is not getting to high 220deg will not hurt it any.
