Case W3 loader/backhoe
Henry Wixon
11-09-2002 18:03:25
I need a backhoe to dig a septic system and do other projects around my property, and there is a W3 for sale. It's rough, but everything seems to work except the power steering. There's no leakage around the steering cylinder or hoses, so I assume the problem is the pump.
Is that a reasonable assumption? Are parts available to rebuild the pump? Can a shade tree mechanic like myself (I managed to rebuild the hydraulic pump on my Ford 640) take on this job?
Also, the steering wheel slides up and down about an inch as the wheel is turned. This can't be good, but is it terrible?
The rear tires are about 20%. Does anyone have a sense of what would be a fair price for this loader/backhoe? There are no W3 prices listed under Case on the Yesterday's Tractor site.
Thanks in advance for any help you can offer.
Jason Stiehl
11-20-2002 17:13:55
 Re: Case W3 loader/backhoe in reply to Henry Wixon, 11-09-2002 18:03:25
did you by that W3? i have one that was given to me and i have been trying to put it back together i was doing good till i ran into a problem with the power steering cylinder and i now i can't find one and mine is to fare gone to have rebulit. if you did not bye this would you mind telling me were it is if it is still there?
Dennis/Ohio
11-10-2002 02:59:07
Hi, Search the archives for W3, some posts there. Its built around a 530 Utility tractor. I think it has the single power assist cylinder on the front axle and the pump won't be rebuildable. I have a 530TLB I restored and many new parts are not available. I recommend 580CK or newer for that reason. 580 parts are plentiful and 580 holds its resale value....Dennis.....
