More hp.
Dick
11-06-2002 08:58:37
I just overhauled my 731c Case this spring. I have found a parked 830 with a turbo, will the turbo work on my tractor without too much trouble ? Would it be easier to turn up the pump and injectors. Thanks in advance.
Zach
11-06-2002 19:48:50
 Re: More hp. in reply to Dick, 11-06-2002 08:58:37
putting a turbo on it and turning it up will boost the hp. our 1070 has a 1570 turbo and its turned up and is pushing 145 hp stock is 110 hp had it for 15 years engine was stuck didn't do an over haul on it just broke it loose and it still runs great has alot of blow by but it runs good.
david
11-06-2002 17:50:04
Turning up the pump won't get you much w/o a turbo (just makes more black smoke). Putting on a turbo without turning up the pump just runs the engine lean with a surplus of air. Putting a turbo and turning up a tractor engineered to not have them will shorten the life of the engine exponentially (turbo engines have different rings, lower compression, maybe different casting treatments, bigger radiators, and (maybe) different timing, plus overheat as the radiator is probably not built for the extra heat.
Not to sound like a stick in the mud but if you need a bigger tractor, get one.
Dick
11-08-2002 05:23:28
 Re: Re: More hp. in reply to david, 11-06-2002 17:50:04
Thanks David, This is really a great tractor that I plan on keeping for a while longer.
