SC Case oil pump rebuild using SB chevy pump
sbaas
03-17-2006 19:08:45
third party image
Here is a SC engine oil pump rebuild that my machinist friend and I did since oil pumps are not available for this tractor. 1. cut old oil pump in two, milled top half flat,drilled out center and installed bushing.
2. Milled chevy pump flat.
3. Milled from aluminum block adapter plate.
4. Cut old shaft to length and reshape end to fit in chevy pump,also install collar on shaft so it wouldn't fall out
5. Oil flows out chevy pump through adaptor to fitting and steel line plumbed to side of engine block. Oil goes to remote filter and then back into engine from side of block.
6. Reshape pan to fit new pump.
Solid 35 psi oil pressure. It's nice to know a machinist!!
george md
03-18-2006 11:53:51
 Re: SC Case oil pump rebuild using SB chevy pump in reply to sbaas, 03-17-2006 19:08:45
Super job ,I like to see a real full flow filter
on the older engines . I converted a 47 caddy from partial to full flow,
I did it much like chevy small block , put a soft
plug in the vertical oil gallery and drilled before
and after the plug to get the oilout and back in,
worked well. Also used a chevy 6.2 pump to replace the pump
in a J series continental diesel ( case 1000 crawler ), mounted it on the end of the balancer.
george
sbaas
03-17-2006 19:15:38
Link
Link
Link
Link
Link
Link
Link
Link
Link
Link
Link
Link
Here are links to pictures of the project.
