Trouble shooting 400 hyd.
T.Wood
11-05-2002 13:24:57
I have been working on a project for some time. I purchased a case 400 251 gas at an auction a few years back. The tractor was split, engine stuck, and heads cracked. After a complete engine overhaul, which was a little more difficult, because of parts availability for the early model I got it all together and it runs like a dream. The trans took some getting used to but it's starting to grow on me, although it will sometimes slip out of sixth gear. One of the first things I noticed was the hitch would not raise and I had no pressure at the hyd outlets. My first step was to flush the resivior, clean the filter, and replace with new fluid. I used a trans/hyd fluid. I've seen mixed postings regarding this and atf. Still no movement or pressure, so now I check the return balls and springs where the hoses thread to the heads. AHH one spring was broken and another one had been put in backwards. After I put these parts back in order My hitch works well and I use it with my brush hog, but I don't have much pressure at the outlets. I could work a cyl. sitting on the floor but couldn't lift my hay rake. So I get a gauge and plug it into the 1/8" Pipe thread by the relief valve and it reads 300psi only when I push the hyd. lever forward. At any other position It reads 0. When I removed the cap for the relief valve I could easily see that the spring had been ground on and part of it was missing. Reading my service book I see that adding shims should increase pressure. I added 1-2 washers at a time untill I could hardley get the cap on and saw no change. At this point I removed the heads just to make sure everything was there and wasn't broken, backwards, or in the wrong spot. Some of the springs were somewhat rough and sharp on the ends but otherwise everything "looked" o.k. I reseated all the balls with a drift and reassembled with no changes.
The old single spring is not available, and 2 springs with a spacer replace it except the spacer is no longer available and the two springs cost $35.00.
Thanks For taking the time to read this and what do you think?
Larry
11-06-2002 06:06:52
 Re: Trouble shooting 400 hyd. in reply to T.Wood, 11-05-2002 13:24:57
Looks like you covered everything. Now the only thing you need to look into is the pump.
Charley
11-06-2002 16:28:04
 Re: Re: Trouble shooting 400 hyd. in reply to Larry, 11-06-2002 06:06:52
I had the same problem with a 730, which has about the same hydraulic system. Turned out to be the relief valve. Had to buy a rebuilt valve assembly and that fixed the problem.
TWOOD
11-06-2002 17:27:43
 Re: Re: Re: Trouble shooting 400 hyd. in reply to Charley, 11-06-2002 16:28:04
To change the relief valve in your 730 did you have to tape the seat and remove it with a threaded puller. If so did you do this with the unit on the tractor, and what about those metal shavings from the tap? Is there a good easy check for the hyd. pump? Thanks
Charley
11-07-2002 08:14:57
 Re: Re: Re: Re: Trouble shooting 400 hyd. in reply to TWOOD, 11-06-2002 17:27:43
Yes you need to take the remote off the tractor. I unfortunately replaced the pump and when that didn't help I started looking more closely at the valve. The manual says to tap the seat and keep the shavings out of the remote with towels or grease. I got a rebuilt valve from Elmers in Centralia, Kansas. They had told me that shims wouldn't help if the seat was leaking. They were right.
