Need a used pto
Zach
11-05-2002 06:08:16
Hey i need a used pto or just the shaft for a 430\400b tractor our local junkyard don't have to many case tractors i guess because all of them are still up and running. ;) thanks
JEAN CLAUDE MARLEAU
11-05-2002 07:19:05
 Re: Need a used pto in reply to Zach, 11-05-2002 06:08:16
hi zach I do have a shaft but need to know if it is an independent pt.o and or a live drive not the same i do presume you are talking of the shaft that hook to the implements behind. my email is [email protected]
Zach
11-08-2002 21:40:25
 Re: Re: Need a used pto in reply to JEAN CLAUDE MARLEAU, 11-05-2002 07:19:05
i need the shaft that goes from the pto houseing into the rearend to the clutch\pressure plate. the one for the 430 is on our 400 and the 400 case o matic is longer soo we cut it and shortend it and there was a pipe over the spliced place and it hitt.we can cut and weld again but with outthe pipe but it would be better with a solid one.
