Timing/magneto Model D
Ken Tabor
11-05-2002 05:30:04
I have a case model D, 1950. Tried to set the ignition timing last weekend and ran out of adjustment on the magneto housing before the timing was correct. It is a case tractor but has an internation harvester mageto. Does anyone know if the angle on the magneto coupling is the same? The case impulse coupling is at I believe 25 degrees. If the IH magneto is different, then this may be why I don't have enough adjustment.
North M
11-05-2002 07:06:43
 Re: Timing/magneto Model D in reply to Ken Tabor, 11-05-2002 05:30:04
I have a mag off of a farmall H on my case D and it works fine. Lots of adjustment. Just wondering if you have the D timed right?
