Muffler or no muffler ?
Robert P
11-04-2002 14:37:21
Recently got my hands on an old CASE VAC in working condition. The muffler is missing. If I put a straight exhaust pipe with an exhaust cap will it affect the engine or its performance ?
BCdave
11-08-2002 18:22:41
 Re: Muffler or no muffler ? in reply to Robert P, 11-04-2002 14:37:21
I am in the process of restoring my Dads VAO that he bought in 1947. The exhaust pipe on it is cast and there is no way to attach a muffler. I have other motors where the pipe is round for mufflers. I guess thats why I say EH!!! Tooo many hours as a kid driving the case in the orchard! I still love that sound.
Dave
John H
11-06-2002 17:16:45
As I stated in a post below on the SC please put the muffler on. Take it from someone who spent hours on a C your hearing will appreciate it a couple of years from now.
Jim P
11-05-2002 21:44:33
The L came without a muffler and didn't even have much of a pipe, first one pointed down about 30 degrees and was about 5 in. long. Trouble is factory mufflers put too much backpressure and thats kills power and I would think that could be hard on valves..Remember putting cherry bombs on your old Chev.? Just my two cents worth. by the way I put a airplane muffler(and old one I had lying around) on my VAI. couldn't stand the sound without a muffler. I run a 900 Lp without a muffler, because my trees would tear off a muffler, so all I can do now is say HUH!!
Eddie in KY
11-05-2002 20:06:59
Technically a muffler does several things, one is quieten, another is spark arrest, another is back pressure which also keeps some unburnt fuel in cylinder to be burnt on next stroke, as well as maintaining some exhaust pressure to keep cold air away from valves. Running muffler free will actually lean out the fuel/air mixture somewhat so you may find a need to adjust the carb to richen it up some. Personally, The factory had it set up for best all around (stock) performance in my opinion. I would put the muffler back on. But thats just another opinion, and we all know what is said about opinions.
Be Careful
11-05-2002 19:08:45
If you allow cold air to enter a straight pipe it can warp the valves and cause big problems. Part of a muffler's job is to maintain a slight pressure and ensure only warm air backfeeds to the exhaust valves and manifold.
C. Amick
11-05-2002 09:21:32
It should actually boost the horsepower a little. It will be very loud at full throttle. If you are going to use it much, I would suggest ear plugs. I wear them when I mow with my VAC. I need a new muffler.
Zach
11-04-2002 20:05:08
It will have some effect on performance. With no muffler it will have less backpressure which bumps the hp up just alittle it might or might not be noticeable.
Les
11-04-2002 15:16:41
My VAC has no muffler. That's the only way I've ever known it but I doubt it will have any effect on performance. It's not really that loud.
