Need help identifying part
Jeb Mccranie
11-03-2002 17:34:15
I found a rubber gasket for my 1290, and I am not sure where it goes. Part number is K961674. Thanks.
JEAN CLAUDE MARLEAU
11-04-2002 20:15:04
 Re: Need help identifying part in reply to Jeb Mccranie, 11-03-2002 17:34:15
sorry jeb but if that gasket is too large than you are giving me a part no. that is wrong for this item i sold that gasket for at least 30 years under part no. k961674 for the sediment bowl on all david brown tractor. sorry but the partmen gave you the wrong item.
JEAN CLAUDE MARLEAU
11-04-2002 09:44:05
HI JEB THIS RUBBER GASKET IS FOR THE SEDIMENT BOWL UNDERNEATH PRIME FUEL PUMP IF YOU CHANGE YOUR FUEL PUMP WITHIN THE LAST 3 OR 4 YEARS CHANCES ARE YOU MAY NOT NEED IT ANYMORE CAUSE ON THE NEWER PUMP CASE DISREGARDED THE FUEL BOWL.
Jeb Mccranie
11-04-2002 13:13:59
 Re: Re: Need help identifying part in reply to JEAN CLAUDE MARLEAU , 11-04-2002 09:44:05
I don't think it is for the fuel bowl. it is bigger than than the bowl itself
