Case VAC questions
Ken
11-03-2002 06:23:25
Just bought an 1947 Case and I am looking to repair a few things. I dont know if I am missing parts or the lift hitch wont work. Is there supposed to be a hydraulic cylinder that lifts the hitch or is it all mechanical? There is a lever that goes down to some type of hyd valve. When I push it one way nothing happens and when I push it the other way it grinds like gears trying to engage. If any body has pictures of thier VAC I sure would like to see them, close ups would be helpful in trying to figure out if I am missing parts. Thanks for all your help
Jim P
11-05-2002 21:55:26
 Re: Case VAC questions in reply to Ken , 11-03-2002 06:23:25
I didn't think the VAI was that different from the VAC when it came to the Hyda Pump. I guess I was wrong. My Hyda. pump on my 1947 VAI was on the right front of the motor and run off the crank and cam gears. My lines were hard lines and went back to a simi-mounted cly. that lifted a side mount mower. I piped in and run hose to a hand valve to lift my loader.
C. Amick
11-05-2002 09:46:06
The hydraulic pump sets under the shaft that drives the belt pulley. Actually, the belt pulley shaft also runs the hydraulic pump. There should be a hydraulic hose coming out of the pump going to a hydraulic jack across on the left side of the tractor. If the jack and hose are not there, someone has likely plugged off the hose connection. The pump may be trying to operate and can't pump the oil anywhere. Make sure it has oil in it. My dad always used auto transmission fluid. The fill plug is up on the top of the belt pulley housing. There should also be a brass bleeder valve near where the control rod connects to bleed the air out of the system.
Ken
11-05-2002 17:22:24
 Re: Re: Case VAC questions in reply to C. Amick, 11-05-2002 09:46:06
Thanks for your help. It looks like I am missing the Hydraulic Hose and Cylinder. Do you remember or know how big of cylinder it was? Thanks again
