DC Hydraulic Pump Gasket
Paul f
11-01-2002 06:24:06
I am in need of wisdom from this august group. I am ready to mount the hydraulic pump on my 54 DC3. The big gasket between the pump and the tractor is no longer available from Case. What should I use? Paper
Cork
Silicon
None of the above
Combinations
Thanks
Craig
11-04-2002 12:11:24
 Re: DC Hydraulic Pump Gasket in reply to Paul f, 11-01-2002 06:24:06
I rebuilt the pump on my 1954 DC-3. I used paper gasket material & it leaked. I found out the hard way that using silicone in a tube is about the only way it will seal with all the imperfections in the castings. Hopefully you don't have as much trouble as I did. I believe it took about 3 tries to get the proper seal between the pump & the tractor.
Larry
11-01-2002 06:36:51
If you're good at making gaskets a paper one would be the best. I have already used silicon with good results too,but don't use too much. The excess will end up in the resivoir.
