VAI crank specs
Brent
10-31-2002 21:29:45
We just got a complete VAI that's in pretty good shape. It had a very slight engine knock (I could barely hear it). I took the oil pan off, and sure enough, the rod bearing on #4 cylinder is spun really bad - not much left.
Does anyone have the specs on the crank journal diameters? And how about the connecting rod bearing diameters? Just wanting to know how bad it is. I haven't miked the good journals or the spun journal yet. I assume that we can have the crank welded to build up the damaged surface, if necessary. Please give any advice on this.
Thanks in advance...we should be getting pretty good at fixing tractors with spun bearings... ;-)
mj
11-01-2002 08:08:45
 Re: VAI crank specs in reply to Brent, 10-31-2002 21:29:45
If the journal is scored but has some area(s) of "to spec" diameter remaining and any potentially bearing-damaging high spots are eliminated a fresh bearing will usually run and live....assuming, of course, that the block/insert interface is still good. Good luck and may the spirit of J.I. Case smile upon you!
Bill Hires
11-01-2002 04:24:57
Crankshaft Journal Diameter 2.2495. Running clearance 1.5-3. Torque 95. Crankpin Diameter 1.937 Running clearance 1.5-2. Torque 60
