DB 880 hitch drooping
D.L.
10-30-2002 15:44:48
I've noticed that when I have a load on the hitch of my DB 880, over a period of a few minutes, it will sag to the ground and I have to bump it back up with the lever.
Is this a sign of a bad control valve, or does this have something to do with the bypass valve?
Bear
11-13-2002 06:56:09
 Re: DB 880 hitch drooping in reply to D.L., 10-30-2002 15:44:48
I had a similar problem with my DB880 and it turned out to be water in the hydraulic fluid.
Jeb Mccranie
11-02-2002 18:34:50
IT could be both. If you hear a loud chattering or squealing noise it might be the pump trying to seize. I drove a ford that had the same problem one time and it turned out to be the control valve. It was full of sludge because the owner had never changed the transmission filter
