David Brown wheel dishes
Rick Cook
10-29-2002 16:30:31
I am looking for rear wheel dishes to fit on a 1963 David Brown 990 Implematic.
The centre hub hole is 5 15/16" - 6" diameter.
The wheel studs are in a 6 bolt pattern with 7" diameter between opposing studs.
I believe the outside diameter of the dish is 28' but that is not particularly important for my purposes.
What I am wondering is there any other dishes except for DB that come with a 6 bolt pattern in a 7" diameter around a hub cut-out of 6"?
Posted to Tractor Talk and Case lists.
Thanks, Rick
Elmer
10-29-2002 18:43:43
 Re: David Brown wheel dishes in reply to Rick Cook, 10-29-2002 16:30:31
Where are you located. I have a set of rear wheels for the 990 implematic.
