Transmission filter
Jeb Mccranie
10-29-2002 15:02:38
Where is the transmission filter on a Case 1290 located at. Is it under the little rubber circle located beneath the tractor. One guy even said that I would have to split the tractor to get to it. Also, how often should I cahang the filter and fluid. Never has been changed since it left the factory.
Elmer
10-30-2002 04:25:57
 Re: Transmission filter in reply to Jeb Mccranie, 10-29-2002 15:02:38
Look under the tractor at the drawbar area, between the foot boards. You will see a round canister with a plug on the side of it. There is also a drain plug about a foot to the rear of the filter on the rear axle housing. Make sure you still have the bypass screen in the filter as well. I have seen tractors without the screen. I guess when people drop everything into a pail they just grab out the canister and install a new filter and never saw the bypass screen in the old filter. That way the oil goes straight through the filter and not through the paper. I get the tractor to fix when the dirt and crap ends up in the 3 point hitch control valve. Change the filter and fluid once a year, mainly in the fall. Keep moisture out of the system. Oil and filters are cheap compared to a control valve!!!
